slow speed. data is disappearing even when computer and other devices are off. Can't access use meter.
I have resolved to using this service only for browsing because the data is being drained so quickly. Now I can't even get through a month when I only use it for essential internet use such as bill paying and shopping. Also cannot access the usage meter to see where I am.The sales rep painted a very different picture than what I am receiving. I also have not received the $50 credit that was promised when I signed on. I don't think I could be less satisfied. I had some conversations here a month or two ago and can't access them.
3 REPLIES 3
Re: slow speed. data is disappearing even when computer and other devices are off. Can't access use meter.
kieferr111, you should see a meter here: http://192.168.0.1/
If you can't load that page then you may have a local network problem. Are you using a wireless router?
https://community.myhughesnet.com/hug...
The topic links are posted above.
You never responded to them.
Hello kieferr111,
We've offered a couple of times before to assist you in regards to your data concerns. Were you able to do anything we recommended in the links posted by Gwalk900?
Thanks
