I did not receive any emails as you must have sent it to the general HughesNet support email. Once you run the 3-5 speeds tests across a few days, I will have a more accurate way of going about troubleshooting as I do not want to perform actions that are unnecessary at the moment.
-Damian
Did a lot of tests. Some of them I flat don't believe but the link is Testmy.net/quickstats/Dar00 The identifier is Home.
You can use this link, which is for dar00's tests with the Home identifier...
https://testmy.net/quickstats/Dar00?type=user_name&q=Dar00&extraIDX=1
Thank you for providing me this information and you as well @GabeU. This has been most helpful. It appears we do not have communication with your modem currently. Is it currently unplugged? If it is, once it is plugged back in, I will be sending commands to your modem with instructions to reset parameters in a specific order. This is one of the first steps to perform in a situation like this.
-Damian
The Modem is generally on between 10 am and 11 pm Pacific time.
Thank you for your patience. I was able to send commands to the modem. Please allow a few hours and run a speed test again. Once you do, let me know what your results were.
-Damian
On Testmy. Results were 1.9 down and 1.2 up. Not good.
The only device I see connected to the modem is an unknown device on the 5GHz network with a fair signal instead of a good one. Please connect a device to the modem directly via Ethernet cable when running diagnostics. This is because the number your modem is reporting is much higher than the results from the speed test you have recently run. Devices connected with fair/poor signal will always report lower numbers. Direct connection rules this out completely.
-Damian
The unnamed device is a cell phone. All speed tests have been done with my desktop and a direct connection via cable to the modem. Did a test a few minutes ago and the download was 900kb and the upload was 1.2mb.
Dar00
Damian
What's going on? Connection still the same. bad.
Dar00
