speed test
5 REPLIES 5
Distinguished Professor I
Re: speed test
Please provide a link to your results page.
https://testmy.net/quickstats/[yourusername]
A link to one test isn't useful.
e2x10 wrote:
https://testmy.net/auto?extraID=7&schVar1=Auto&st=1&r_time=1&xtimes=12 slow
Re: speed test
@e2x10
This is your link...
https://testmy.net/quickstats/e2x10
When you run the tests, please be sure to follow these instructions fully.  Please be sure to use the correct test file sizes and disable the WiFi in the HT2000W modem while running the tests.
Also, please indicate whether you are out of plan data.
speed test
Tags (1)
Re: speed test
Please continue with your prior topic.
https://community.hughesnet.com/t5/Tech-Support/speed-test/m-p/121203
Edit:  Also, please thoroughly read the speed testing instructions I linked to in the other topic and run the tests as instructed, including using the proper test sizes.
Re: speed test
Good morning e2x10,
We're closing this thread since we never got a reply from you. If you still have concerns, please start a new thread and include a detailed explanation so we can more effectively help you.
