use less that 300 mb get hit for over 800 on the same day
Alum
Re: use less that 300 mb get hit for over 800 on the same day
Hi Gary,
You're reading the status meter wrong unfortunately. I'll start from the 19th to the 20th. It's depicted as a line graph so I can understand the confusion. This is how you should be reading it. From 12:00 am on the 19th to 12:00 am on the 20th you used 846 MB. Then from 12:01 am on the 20th to 12 am of the 21st you used the 320 MB you are referring to. Do you understand what I mean? Your comparing a line graph to a bar graph yet they are read differently. Let me know if that makes sense.
EDIT: Maybe this is simpler, by the end of the day on the 20th the status meter line drops down to about 300 MB used which is the total for the day. Which matches the CMC usage.
- Chris
Well Chris I really don't care as Exede will give me 10GB daytime for the same price I pay HughesNet for 5GB so December will be my last month with Hughes anyway as my 2 year contract will be over so disregard this message I am fed up.
Alum
Hi Gary,
I'm sorry to hear that. I'll go ahead and close this thread for you.
Chris
