Chromecast...what's the advantage?
Professor
Re: Chromecast...what's the advantage?
I do have it set up to turn off when the TV is off.  I just noticed that when it was in use, it didn't seem to use a lot of data for the backdrops.  I have the 2nd generation Chromecast. Would that make a difference? ETA: I imagine that because I don't have it on for long, and I'm streaming when using it, I may not have noticed a huge use of data. But since the backdrops are images that are downloaded, it makes sense they use up data.
I have the Chromcast connected using the USB port on the TV -- so when the TV  is off, no power goes to the Chromecast.
Nope, I have 2nd generation also. You should read this if you haven't already: https://www.howtogeek.com/337719/how-to-tame-your-chromecasts-background-data-usage/
My guess is like I said, you haven't left it on long enough to notice a big difference. Either that or what is being used by Backdrop you are thinking is being consumed by whatever online streaming you are doing.
Professor
Yes, I think you're definitely right, BirdDog.
Option 2 in that link is what really saves the data when the Chromecast is powered up. I made my own 1x1 pixel .bmp images instead of the author's. Mine are only 58 bytes in size compared to his 600+ kb size. Even that difference saves a lot when the images are being refreshed every 30 seconds.
Professor
That's really cool, BirdDog.  I didn't even know that it could be done (Option 2).
@BirdDogwrote:
Option 2 in that link is what really saves the data when the Chromecast is powered up. I made my own 1x1 pixel .bmp images instead it the author's. Mine are only 58 bytes in size compared to his 600+ kb size. Even that difference save a lot when the images are being refreshed every 30 seconds.
Distinguished Professor III
@maratsadewrote:
I revert to the HDMI cable and using a wireless mouse to control the laptop. (I use a short HDMI cable)
Ya know, sometimes things are right in front of you and you feel like a moron for not seeing them.  I have a wireless mouse, but it never dawned on me to just use the mouse as a remote and have the laptop out of the way so I don't have to trip over the cable.  SMH.  Just unbelievable.  That's a HUGE DERP moment.  Smiley Tongue
Lol, I used to do that. Just got tired of lugging the laptop out to the TV to connect the HDMI.
I guess they are all fairly similar but my favorite is the Roku, I just bought another Roku Express last week for $26 from Wal Mart. I don't know whether the Chromecast does this but apart from the freebie channels Roku also allows you to add channels some of which you may already subscribe to through your Dish/Direct Tv subscription. The advantage of this is if you have a TV in a room with no cable/satellite feed you can still watch things like abc, BBC etc. for no additional cost providing you are connected to your WiFi/Internet. Also certain Roku devices have a USB port enabling you to play your home media if ever you lose your WiFi. I have said a few times before I like to combine the PlayOn server with my Roku devices because of the off peak recording feature, I can watch pre-recorded movies and series on any TV in the house using WiFi (no internet required). I believe PlayOn supports Chromecast https://www.playon.tv/features . Regarding smart phones with Android OS there is an app called Allcast that allows you to cast vids to your streaming device, I don't use that much it's more of a novelty. I bought my first Roku 3 or 4 years ago, zero data leakage that I have seen.
Does Roku stream from a laptop or from the internet itself?  The reason I ask is because I like the control of my laptop and to be able to change the resolution and such of the Youtube videos or other players.
Maybe I'm not quite clear on what Chromecast is.  I thought it was simply a device to wirelessly cast whatever is showing on your laptop to your TV, including streaming, and with the audio.  I didn't know that it only works with certain streaming apps and such, meaning not everything.  I thought it basically took the place of my HDMI cable from my laptop to my TV, and ANYTHING I could show in my TV with my HDMI cable would show with Chromecast.  I didn't know that it relied on app compatibility.  Like if I were playing a video game on my laptop I could cast it to my TV and could view it there instead of on my laptop.
I just watched a Youtube vid about streaming Youtube and there were all these things you had to press, with Chromecast button showing up on Youtube itself.
A little different than I thought it was.
