Does Gen5 allow a public IP Adress and port forwarding?
Re: Does Gen5 allow a public IP Adress and port forwarding?
@byronics wrote:
You used the IP address the satellite assigned you, and then just forwarded 2 ports to view your NVR???
As previously stated, HughesNet uses dynamic IP addresses, not static IPs.  The IPs are also shared between multiple users.  The IP assigned to you is temporary and changes often.
If you require a static IP, they are offered for the Business Plans.
