Hughesnet Community
Wifi going down
farmerhugh
Junior
Wifi going down
Could someone tell me what the indicators are for a router going bad.  My wifi keep shutting down  suddenly and I don't think its the internet.  It seems to spring back to life when I wake up my wired desktop.  Appreciate your suggestions.  I did go into netgear and check for updates and all was fine.
1 ACCEPTED SOLUTION
Hey farmerhugh
Thanks
29 REPLIES 29
farmerhugh
Junior
hi Amanda, Received new router last night and hooked it up this morning.  Many thanks to you and Hughes Net.    We really appreciate it!!!
Hey there! Glad to hear it. Let us know if that helps with the wifi problem 🙂
farmerhugh,
Is it the D-Link DIR-619L?
farmerhugh
Junior
n=300 Cloud router D-Link  so far-all is good
farmerhugh
Junior
2 laptops, but only run 1 at a time.  seems the new router has solved the problem.  The people in this community are really a great help!!
That's actually the type/category of router it is.  I'm fairly sure it's a DIR-619L, but I was just curious.  It's not that important.
farmerhugh
Junior
Yes Gabe it is.working real good!!!
Hi farmerhugh,
I am so glad to hear that. We work really hard to make this community a place for customers to have an experience like yours. We hope you will stay with us and come here if you ever need anything! Happy Holidays!!
Glad you like it.  It's a decent router with a fairly good range.  My folks also have the same one and my stepfather can go anywhere in his two story house with his laptop.
I've also found absolutely zero drop in speed between being directly connected and using this router.
