Wifi going down
Gwalk900
Re: Wifi going down
May not be the issue in your case but is one less thing out of the way.
Don't forget to post when you get the new router
farmerhugh
Re: Wifi going down
hi Amanda, Received new router last night and hooked it up this morning.  Many thanks to you and Hughes Net.    We really appreciate it!!!
Re: Wifi going down
Hey there! Glad to hear it. Let us know if that helps with the wifi problem Smiley Happy
Re: Wifi going down
farmerhugh,
Is it the D-Link DIR-619L?
farmerhugh
Re: Wifi going down
n=300 Cloud router D-Link  so far-all is good
farmerhugh
Re: Wifi going down
2 laptops, but only run 1 at a time.  seems the new router has solved the problem.  The people in this community are really a great help!!
Re: Wifi going down
That's actually the type/category of router it is.  I'm fairly sure it's a DIR-619L, but I was just curious.  It's not that important.
farmerhugh
Re: Wifi going down
Yes Gabe it is.working real good!!!
Re: Wifi going down
Hi farmerhugh,
I am so glad to hear that. We work really hard to make this community a place for customers to have an experience like yours. We hope you will stay with us and come here if you ever need anything! Happy Holidays!!
Re: Wifi going down
Glad you like it.  It's a decent router with a fairly good range.  My folks also have the same one and my stepfather can go anywhere in his two story house with his laptop.
I've also found absolutely zero drop in speed between being directly connected and using this router.
