I just set up a new D-Link router, as my Netgear router was getting a little temperamental. The settings are nothing like my Netgear settings, which actually had a program to get into them. With the D-Link it's through the address bar. The only options it gives me in the wireless settings is "Disable Wireless Security (Not recommended)" and "AUTO-WPA/WPA2 (Recommended)". I imagine I would choose the 2nd, right?
I often see people saying to disable WAP, but I don't see anything for it.
Any help as to what settings I need to change, what to change them to, and how to change them would be greatly appreciated.
Also, does D-Link have a program, like Netgear does, so that you can get into more advanced settings, or is the address bar method and the few things that are able to be changed through such the only way?
Thanks for the help.
