we recently agreed to sign an agreement with Hughesnet after speaking with several salespeople and reading the webpages such as this one below on this page.
https://www.hughesnet.com/about/hughesnet-gen5
It clearly says I will experience "If you exceed your monthly plan data, you will experience reduced speeds, typically1-3 Mbps, until the next billing cycle."
I am a CISCO engineer who works constantly through the internet. my required speed is around 56kbps. or around 256 kbps for some jobs. I was told repeatedly that when my data plan was used the 20 Gbs no problem my speed would be reduced to 1 to 3 mbps. That 1 MBPS is still acceptable, however since having the internet for 2 months, we have found that even when I disconnected everything, and I use a fresh OS install connected by ethernet we get speeds WAY under 1 mbps.
When I contacted customer support I spent 6 hours of my time-wasting asking for them to check my connection only to have them refer me to the FUA.
I want someone to check our sales call and tell me why we are getting speeds way under 3, or 1 mbps?
