GEN-5 Speed faster than advertised
I'm right where I put the yellow dot in Western, NY. Not in the center of the beam, but still not a bad placement. My RSS is sitting at 99 right now, but it's overcast. I also don't know where my Gateway is to know what the weather is like. Wherever ROS is. Roswell, NM?
I may be wrong but I think you all up north get lower signal by default just because you're farther away.
Yes, I think there's a Roswell gateway on Gwalk's map. Looks like beautiful weather in Roswell tonight.
GW wrote:I may be wrong but I think you all up north get lower signal by default just because you're farther away.
https://www.wunderground.com/US/NM/Roswell.html
On his map there's one in Albuquerque, but not Roswell. There're most likely Gateways for Gen5 that aren't on that map, though.
There are a few Jupiter II only gateways that aren't on that map... I happen to be on one of them, and Gabe happens to be on another one of them it seems.
