larrykelly
9 years agoJunior
GEN-5 Speed faster than advertised
I ran a speed test using a utility different than HughesNet's and got the same excellent results. Notice the test results from a year ago of GEN-4 which I considered pretty good at the time. I just u...
C0RR0SIVE
9 years agoAssociate Professor
tampasteve1 wrote:I am not sure if anyone has gone through their data for the month yet, but are there any stats on what the speed is once you pop your cap on Gen5?
I have been trying to FAP but I am in the 20 day resets since my install was considered a new install... I think someone at DSLR managed to FAP a unit and it showed ~3Mbps peak for their FAP speed, of course that's likely to change as time goes on. Once I FAP my unit, I will try to get some test results.
GW I have seen a very steady and stable speed with my Gen5 unit... http://testmy.net/stats/?&t=u&l=250&z=30&q=C0RR0SIVE
GW
9 years agoAdvanced Tutor
Thanks. All I see for primetime testing is on Sunday 3/19 but those held up very well compared to the misery inflicted upon users of E17 Beam 55
