larrykelly
9 years agoJunior
GEN-5 Speed faster than advertised
I ran a speed test using a utility different than HughesNet's and got the same excellent results. Notice the test results from a year ago of GEN-4 which I considered pretty good at the time. I just u...
GW
9 years agoAdvanced Tutor
I may be wrong but I think you all up north get lower signal by default just because you're farther away.
Yes, I think there's a Roswell gateway on Gwalk's map. Looks like beautiful weather in Roswell tonight.
9 years agoDistinguished Professor IV
GW wrote:I may be wrong but I think you all up north get lower signal by default just because you're farther away.
https://www.wunderground.com/US/NM/Roswell.html
On his map there's one in Albuquerque, but not Roswell. There're most likely Gateways for Gen5 that aren't on that map, though.
There are a few Jupiter II only gateways that aren't on that map... I happen to be on one of them, and Gabe happens to be on another one of them it seems.
