Anytime Data Seems to have disappeared into thin air and now state code 12.7.2
Hello,
My anytime data reset last week. On the same day, 15 GBs of it seems to have disappeared into thin air. Even though nobody was home most of the day and my electronics are set to not update. The connection was also incredibly slow that day. Now, my connection keeps going out. The modem says state code 12.7.2 whenever it happens.
Please help!
13 REPLIES 13
Re: Anytime Data Seems to have disappeared into thin air and now state code 12.7.2
Jb1985,
Regarding the data disappearing, the following thread may help....  https://community.hughesnet.com/t5/Tech-Support/Understanding-data-usage-data-loss-and-connection-pa...
Do you have a satellite TV receiver connected to your service, by chance?
As for the state code, it indicates a connection issue, though connection issues can be caused by a few different things.  The reps will most likely want to run some remote diagnostics to check out your equipment.
Out of curiosity, what is your IP Gateway Associate State string on the following page?  http://192.168.0.1/#!/home/status  It will start with either J1 or J2.  This will help to establish where your gateway is, as inclement weather at your gateway can cause connection issues in the same way as inclement weather at your own location.
No satellite receiver connect and it starts with J2.
Okay, what is the string starting with the J2?
BTW, your IPGW string doesn't contain any personal info.  It only contains your gateway, beam and what gateway node you are presently connected to.  So, if you are nervous about posting it you don't need to be (some people get a little nervous about posting info like this).  The only HughesNet related thing you should never post on a public site, besides your personal info, is your account number, which is the number that starts with DSS.
J2SLC097HNSIGW0101
A 12.7.2 means the gateway is having trouble seeing you. It could mean a configuration setting is wrong, a possible power problem, or the alignment is off.
Pretty sure one of the admins (@Amanda or @Liz) can help determine with remote diagnostics and either fix it then, or have a tech sent out, if needed.
Would be helpful to know if the modem is plugged into an electrical circuit meant for lights, and not shared by heavy duty things like refrigerators, clothes washers, air conditioners, and the like; and is plugged directly into the wall without the use of a power strip or other surge protector.
I suspect there was an outage last night... Heard a few others had 12.7.2 pop up last night on J2...
EDIT:  Please try removing power from your modem for ~10 minutes by unplugging it from the wall, then power it up.  That should help clear the particular error you are seeing.
EDIT2: If it keeps going back to 12.7.2, then don't worry about rebooting your modem, let it collect logs so that the moderators have some diagnostics data.  12.7.2 should "heal" on its own in most cases.
See what happens when I don't pay attention?
It’s still giving that error this morning. It will work fine for about 10 minutes and then it will give that error for around 10 minutes.
The modem is plugged directly into the wall and isn’t sharing an outlet with any large appliances.
