Bonus Zone usage going against Regular usage
taz458
Anyone else having this problem ? ... my available data is already down to 35 percent with 25 days remaining.  I have been watching youtube videos from 7 to 8 AM and its using my regular data I do believe ... I have never had this problem until now.
2 REPLIES 2
Distinguished Professor III
Re: Bonus Zone usage going against Regular usage
There may be a delay in usage reporting.  You may need to run tests to show what's going on.  See the info below.
Please perform the following test outlined in the graphic below, though follow the full instructions written below the graphic. This is known as a Modem Isolation Test, and it will help to determine whether the issue is with HughesNet or your local network..
1: Disable the WiFi in the HT2000W modem.
2: Take a screenshot of the Home page of the System Control Center, along with the clock on your computer screen.
3: Disconnect the LAN cable from the modem, noting the date and time of disconnect.
4: Leave the LAN cable disconnected from the modem for several hours. HughesNet recommends doing this overnight, or during the day while at work. DO NOT unplug the modem from the power. The modem must remain powered.
5: Reconnect the LAN cable to the modem, noting the date and time of reconnect.
6: Take a screenshot of the Home page of the System Control Center, along with the clock on your computer screen.
7: Post your screenshots to the community.
The screenshots should look similar to the following, being dependent on the operating system, with the system clock included (you can move the System Control Center data level window to being near the system clock so that it is included more easily).
Do not unplug, power cycle or internally reboot the modem after the test has been run, as the reps need to be able to reconcile your modem data logs with what is shown in the screenshots. Any of those three things will wipe out those logs, rendering the test results moot. Only after the reps have responded with their findings should any of those three things be done.
Please be aware that, if you downloaded any large files just prior to this test, some usage may appear to have occurred due to the slight delay (lag) in the modem reporting the data usage to the server, but it should be rather negligible.
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).
taz458
Thanks so much for providing this info ... I will see about using this to document the data usage if this seems to continue.
