Connection problems
joel_cotten
Connection problems
I have had very slow speeds for a while. Got on the router this morning and the connectivity test says limited connectivity to the gateway.
7 REPLIES 7
joel_cotten
Re: Connection problems
Also transmit problem and degraded operational state
Distinguished Professor III
When you go to this page:  http://192.168.0.1/#!/home/status
what's the number next to State Code?
joel_cotten
12.1.9
I've heard sometimes the 12. codes can be related to weather issues either at your location or at the location of the ground station that feeds the signal to your place.   Do you know where your ground station is  located? They're always in another state.   To find it, go here: http://192.168.0.1/limited.html#!/general/summary
and look at the letter/number combo next to IPGW ID.
In any case, the HN reps here will likely run remote diagnostics on your network and get back to you with their findings. Hang in there!
joel_cotten
No weather issues. Code is J2SDO068HNSIGW1410
Hey! You're on my beam. Smiley Happy
Your gateway is in San Diego, and they virtually never have bad weather.  I hope a mod will run remote diagnostics on your site and maybe figure out what's going on.  Maybe your dish needs repointing, or something.
Jay
joel_cotten,
Thank you for reaching out! Please see my private message for account verification.
-Jay
