FAP Speed = Zero
FAP Speed = Zero
My FAP speed is zero.   I cannot even get to myhughesnet.com to buy tokens.  This has been going on for months.  When I have data, speeds are 29 to 33 mbps, very good.  My system has just been tested by tech person that Hughes sent here.  Test results are perfect, but I still cannot use my computer at all after monthly data used, not even to buy tokens.  As Hughes advertisements  clearly state, "we won't cut you off . . . Stay connected . . .  "   I'm wondering how they get away with this and how many others experience the same situation?
4 REPLIES 4
Re: FAP Speed = Zero
They don't "get away with this", as it's not a common problem.  In fact, in my four years on the support community you're the very first person I've ever seen with this issue.
Are you not able to open any web pages at all while in FAP?  Are your devices connected via LAN cable or WiFi, or even both?
Do the HughesNet Usage Meter or the Mobile app still connect and work while in FAP?  If so, you should be able to buy tokens through them.  Still, you shouldn't have to buy tokens just to have access while in FAP, as you should still have it.
A rep will likely reply to help you.
Distinguished Professor III
What's the size of your data allowance? If you always run out of data, you may want to consider buying tokens at the beginning of the month, when you have data.  They don't expire, so it might make sense in your situation to bank a few.
I am having this exact same issue and since I am trying to work from home now it’s making me go insane. I cannot do anything. I can’t even load the HughesNet app. And why would I want to pay more money to buy tokens when I’m already paying for internet that I can’t use!!! HughesNet is a joke and I can’t wait to be out of my contract.
First, you're piggybacking onto an old thread; to get help, post your issue under a new ticket by going to the Tech Support area and clicking on "start a topic."
If you're just here to rag on HughesNet and announce you can't wait to get out of your contract (which you can do at any time; no one's forcing you to stay), you're in the wrong site. Try social media; this site is for serious subscribers looking for tech and account support. It's not for ranters.
To have speed issues addressed in this community, first you will need to follow the procedure detailed here: https://community.hughesnet.com/t5/Tech-Support/Think-you-have-slow-speeds/m-p/110034#M74607
