HughesNet Community
Facebook Issues... Reps?
@Liz @Amanda @Damian @Jay @Hardy
Is there any way I might be able to get one of you to remotely take a look to make sure everything is okay with my HughesNet equipment?  I have a tree that's grown up considerably, and it's difficult to tell if it's starting to be in the way.  My signal strength is good, usually at around 100 or so, but you never know.  I'm able to remove the tree if I need to.
Also, is there anything that can be done to purge my modem or reset it or something to get rid of any old stuff, if that would have any effect, that is.  I'm having a heck of a problem with Facebook, which seems to be singular to me, and it's not my devices, as it's the same on all three of my computers, with each using different AV and browser extensions.  You can see the whole Facebook debacle here.  I just didn't know if maybe there was something with the modem that could be "jogged", so to speak, to maybe fix this issue, as I've tried pretty much everything I can think of, and things others have suggested, as well.  It's only Facebook.  Other sites are fine.  And that's what's odd.
Thanks.  🙂
66 REPLIES 66
