I have talked with numerous techs have done numerous speed test ( which by the way I can now do in my sleep - NOT FUNNY ! ) With 25 mbps and an allowance of 30 MB; I should be getting better then 200,300,400 sometimes a rare 600 kb's connection on my smart tv, on a continous level day and night - Sun thur Sat. I know not to expect the full 25 mbps but, I should be able to get a hole lot more then 200,300,400, etc.( like maybe half ) On my Smart TV. I can get 2,000 kb's or better Hot Spotting off my phone after using up my phones Hot Spot allowence. If I can do that what's up with Hugesnet ? VERY, VERY, VERY, U N H A P P Y ( not saying what I really would like to say ) Looking for action not words.
When you're experiencing this issue, have you checked your speed with another device? Preferably with a device that's connected to the HughesNet modem with a LAN cable in order to eliminate any possible problems with WiFi. testmy.net is the recommended site (and required when troubleshooting), as is using the manual 25MB test size for a download speed test.
And you're going to get "words", as troubleshooting is the way to find the cause. Without knowing a cause, no action can be taken to fix a problem.
Yes I've hook the same ethernet cable from the TV to a laptop and it gives me good readings. When I speed test it with testmy.net. And, I know what your going to say that it must be the TV but, it can't be the TV 'cause I can get 2,000 + kb's with the Hot Spot from my Galaxy Note 8 phone. And when I try the built in duel wi-fi 2g and 5g I get the same very low kb's reading with testmy.net.
Actually, that's not what I was going to say, as I had only started the troubleshooting process. At this point, I think it's best if the reps try to help you. They're on M-F from approximately 9AM to 6PM EST. They'll likely reply tomorrow.
Hello @VIZIO_MIND ,
Thank you for contacting us. I am sorry to hear you are experiencing this issue. Please private message me the phone number associated with your account and I will run diagnostics on the equipment.
-Damian
