HT1100 modem no system, transmit or receive light
My HT1100 modem only shows the power and LAN light. I have checked all the connections and unplugged multiple times. Including leaving everything unplugged for 10 min. We are having no weather issues and nothing is blocking my dish
16 REPLIES 16
Re: HT1100 modem no system, transmit or receive light
@Reannat
With a device that is directly connected to the HT1100 modem (no router), are you able to get to this page?  If you can, please either post a snapshot of the page (edit out the SAN, which is your account number), or post the State Code you see in the System Summary box near the top of the page and the Satellite Receive Signal Strength in the WAN Info box on the bottom left of the page.  I'm not positive of the placement of these boxes as I have the HT2000W modem, though the info should still be somewhere on that page.
That's if I can but if I can't since my internet is down I can't
If you are in need of assistance, please create a new topic in Tech Support.
No I am not able to navigate to any webpage with my computer plugged directly into the modem
Hello @Reannat,
Thank you for posting. I attempted to check your equipment remotely and was not able to get any communication. Since you state your Power and Lan lights are on, you should be able to get to the System Control Center while connected directly. If the IP address is not working for you, you can also get to it by typing www.systemcontrolcenter.com in the address bar of your browser. Try moving your ethernet cord to a different port if this is still is not working. If you are able to get to this page and provide me with the state code, I will be able to troubleshoot more effectively
-Damian
I didn't even think about the fact that the System Control Center address for an HT1100 might be different than it is for the HT2000W.  In the future I'll be sure to instead use the link you provided when trying to help someone with a modem other than the HT2000W.
Distinguished Professor I
I'm almost positive the IP address has been the same for me from the start, way before HT1100, so I wonder if it has to do with reducing typing mistakes (typing words may reduce mistakes, as opposed to typing IP addresses).
The state code is 11.2.1 - a problem receiving data has occurred
Still waiting for a response. Going 2 days now without internet
