It seems that my HughesNet service and speed is getting slower and slower for about the past 6 weeks. This is just normal usage. I wouldn't even try to watch a movie! This is link to testmy.net results: https://testmy.net/quickstats/Nitaclay
It looks like it gets worse later in the day -- congestion?
For the reps to help, please run a few speed tests using the following protocol. Basically what you already did, but using the manual 25MB size for download tests and 4MB for upload, and disabling the WiFi in the HT2000W, if you hadn't already.
-if testing upload instead of download, use the manual 4MB size upload test file
Okay, just ran another test using the 25MB and 4MB. I do not have WiFi and my modem is HT1100.
