A lot of time has passed with no improvement. Sometimes delays are not too bad, other times abissimal. Tonight (Monday) at aout 8PM a modem conectivity test can be seen below. It says I have good connectivity to the gateway.
Internet nearly unusable for a while due to timeouts.
hamradio,
Thank you very much for the updates! From what I've seen, our engineers are continuing to work on a solution for your area. When you took this test, was it the only one you'd taken? Have other tests produced nearly the same results with delay time? In addition, if you could, please try disabling and re-enabling the web accelerator at your earliest opportunity. This may help with the roundtrip ping time.
Remy
Hi Remy,
I have run the test a number of times over the past month or so. Sometimes it reports 600-750 ms which is reasonable considering geosat transit times. However, all too often it reports 2000-4000+ ms. I run the test most often when I see a dramatic downturn in connection performance. That is when the2K-4K times are reported. Next time I note the issue and run the test, will try with and without accel. activated. I hope engineering can fix the issue - Sure is taking a long time!
A sidebar: In the not so distant past, with my 20GB plan, I would end the month with a little surplus data. I know of no changes in my typical actual usage but this month (for example) my data allocation ran out eight days prior to the end of the month. I could monitor my actual usage but have not bothered since I can't easily monitor my wife's Ipad usage (which has not increased from what I can determine.
The relatively good part... I haven't purchased aditional tokens because even throttled back the overall throughput performance hardly changes. Probably a result of the overriding effect of delays???
Thanks, Woody
Tonight, Friday @ ~9PM the connection all but stopped working. Signal strength was at 107.
A look at the top of the image below pretty much explains why the internet stopped. As you can see...
I performed a power-down modem reset and ran two more tests (2 & 3) with and without Acel enabled. It got better after several minutes but never was very good.
Woody
Looks as if something jammed up the modem, which re-powering solved. The inability to contact the acceleration server was a symptom of that, but not the likely reason. This is also likely separate from the lag issue.
Incidentally, whenever I see something like that - to include not being able to reach a particular web site - that's the first thing I do: re-power and clear the modem's DNS cache. I wish there was a more expedient method to solve it but there isn't.
I still find the high lags very curious. You, maratsade and myself are all on the same beam and we don't experience anything quite that high. This points to something local to you. Has your modem ever been replaced? Installation inspected? Or, perhaps something on your computer is interfering with the TCP stack?
Hi Mark,
The modem was replaced some time back in one attempt to fix the poor throughput. After the change, there was no noticable difference.
A long time ago a field service tech came by with orders to re-adjust my dish. Not sure why since my signal strength (not counting bad weather) is/was typically >100. While he was here performance was reasonable - He spent almost no time investigating further.
As to the TCP stack, I have no idea what could be interferring with in in an imtermittant manner...
FWIW, the DNS server has been changed a couple of times. That did not help either.
Also FWIW, when I run a connectivity test there are significant pauses in the progress bar. More pauses = longer reported delays.
What I find curious is that the problem comes and goes with no known changes on my end. ???
Would be more than happy to further investigate possible issues on my end. Any suggestions?
Today (Sat) at 10:45 AM, got this:
(signal down a bit from usual 100+, at 88 - currently have some rain):
Here is another at 11:05 AM:
After I post this, will pwr dwn the modem then post one more test.
...Woody
Here is after the modem re-start. Signal is up to 97.
Also ran a ping:
Another ping a few minutes later:
Ping response varies a lot. ...656 to 3007 ms...
Woody
The DNS server wouldn't account for the DNS cache inside the modem getting corrupted. In fact, the DNS cache getting corrupted is likely more an indirect result of many DNS queries during a lengthy ping gap.
As far as what's causing the gap, it could be anything from a bad Operating System upgrade, to some hardware inadvertently tying up processing. Something I've even seen lately while using an RTL-SDR is that they can wreak havok if the USB connection is disturbed, almost to the point of causing cyclic kernel panics on my Mac. As an aside, my AirSpy HF+ is a much better device for HF and limited VHF (and isn't as finicky), but the RTL-SDR goes DC-daylight and is best for monitoring trunked comms.
Mark,
Just an FYI... I have a RTL-SDR. Never experienced any resultant problems, have not used it in quite a while. I also have a SDRplay RSPdx. Do use that some. Much nicer than the RTL-SDR!
_W_
I'm having a blast with these things. It's really gotten me back into radio.
I mainly use the RTL-SDR for experimenting with HD Radio (nrsc5, nrsc5-gui on github) and a trunk tracker called SDRTrunk (also on github). All my DXing is done on the AirSpy HF+ Discovery using Gqrx and a thing called SdrDx. The AirSpy is a lot better with sensitivity and dynamic range/image rejection than the RTL-SDR, especially on HF. The RTL-SDR runs a little hot too, so it may be very possible that it has a bad solder joint somewhere.
Edit: Forgot to add that on HF the AirSpy does especially well with digital signals. I can output a DRM signal through a virtual audio cable and decode it using Dream, or do something similar using SDR# in a Windows VM and pipe the audio into MultiPSK. Working more signals than I ever did with my NRD-535D!
