Please tell me theres a Fix
MarkJFine
Re: Please tell me theres a Fix
The 20% packet loss could mean a couple of things:
1. Possible problem with the transceiver.
2. Something possibly interfering with the transceiver (foliage, etc.)
3. Possible misalignment of the dish itself.
What does it say when you go to http://192.168.0.1/limited.html#!/state_code/state_code_monitor or http://192.168.0.1/limited.html#!/diagnostics/curr_hour_history?
Edit: Are you still getting 12.1.9 codes?
NamesTJ
Screen Shot 2018-02-15 at 8.15.38 PM.pngDoes this help? What is going to fix this!? Thanks for any help.
MarkJFine
@NamesTJ
That really only tells a part of the story. What that tells me is that you had transmission errors ~4:45 ET on the 13th, and was unable to reach the backbone at ~13:58 ET on the 14th.
Both of those didn't last very long. The problem is that it doesn't tell me anything about what happened today, which is what the other link would have provided. That said, the diagnostic code shows that the system has been normal for about 3 hours.
Could it have been the weather that was causing the problem today? I noticed there were a few storms that rolled through the middle of beam 66's footprint earlier this morning.
How are you able to tell this from that diagnostic code?  I know the 0005 means normal operation, but I mean the three hours.
MarkJFine
Each 0000 is actually an hour-block prior as you go to the left of the 0005. If there was an error code during the current hour, it would shift one number group to the left each hour until it 'exited'.
Interesting.  Thanks!  Smiley Happy
