I was just installed Wed. My speed is so slow. I have run my test at www.testmy.net. Here are my results.
https://testmy.net/quickstats/wilson2424
Please help!
Joann
While running the speed tests, are you making sure to run them with a single LAN cable connected device and with the HT2000W's WiFi disabled?
Also, if you run more tests, please make sure to space the tests at least five minutes apart from each other.
Edit: I should have mentioned this first, but power cycling your HughesNet modem can sometimes help with your speed. To do this, first shut down your computer, then unplug the HughesNet modem at either the wall outlet or the power pack (NOT at the back of the modem). Wait at least a minute, then plug the modem back in. Wait at least five minutes, then start your computer and test your speed again.
Gabeu, this is a very good friend of mine that needs help. The test were not connected by hard wire. We used the modems wifi setting. Her system is messed up. I Believe her power light was blinking as well. I will be down there again on Monday to further help her with this problem. Thanks for your help.
Modem has been reset.
The reps are sometimes on during the weekends as of late, so she should be sure to leave the modem plugged in in case the reps see this and want to run remote diagnostics.
Regarding the speed testing, if she only has the ability to run the tests via WiFi she should probably hold off on them, at least for now, or at least until you can get there and run some with a LAN cable connected device.
Good luck.
Thanks GabeU. I will be down there on Monday. We will be awaiting the mods instructions.
Hi wilson2424,
I'm glad you found the community, thank you for posting. I ran diagnostics on your site and I'm seeing that the HughesNet equipment is working properly, and currently the speeds being delivered to the modem are ~18 Mbps.
The wifi device HPE26E78 only has a fair connection to the wifi modem. You might want to try moving that device closer to the modem if that's what you're using the run speed tests. However, as the others in this thread have discussed, it would be best to run speed tests while directly connected to the modem and with the wifi disabled to prevent any interference.
Hi Liz and thank you for your reply. There are 3 devices that could possible connect to the modem. The laptop, Ipad and a wireless printer which is HP. She does not have a cable long enough to directly connect to the laptop with where the modem is. I will take a cable down there with me tomorrow to see if I can get it directly hooked up. I think her lights on the modem were going in and out the last time I was down there. I will double check on that issue as well.
Thanks Ricky. I know the installers are supposed to put the modem in an ideal spot where wifi connectivity is best, but I'm curious if that's still the case here.
The laptop that is used is less then 10 feet from the modem when in use. Let's see what I can come up with tomorrow.
There is only about 1 foot of cable that comes through the wall to the modem. No way I can hook directly to the modem and run test. Something just isn't right with this system. I will bring down my computer and hook into the system to see if the computer may be the problem.
