Remote network connection issues
yellicka
I currently work remotely for a company outside of my home state. I'm supposed to access files through a remote network, specifically through a Watchguard Firebox (not a VPN). A computer was shipped to me and I initially didn't have access to 5 of the 6 drives I was supposed to be working on. Working with Watchguard and my employer, I was able to gain access to all but one drive and lost access to the drive I was initially able to get into. Actually, I can access these drives for a few minutes by selecting "Work Offline" under the "Easy Access" tab on the home ribbon of Windows Explorer. After that, I lose acess to any files and have to start over.
My employer has no clue and thinks maybe it's an internet issue. And his networking admin help company doesn't know either.
Does anyone know? Can anyone help?
Thanks for reading.
5 REPLIES 5
Re: Remote network connection issues
@yellicka
Is the computer accessing the files through a VPN?  The reason I ask is that VPNs can be very touchy with HughesNet.  They're very often slow, and sometimes don't connect very well at all.  The high latency and the tools used by HughesNet to mitigate the effects of the latency are what cause the issues with VPNs.
yellicka
The computer is accessing the drives directly through a Watchguard. I actually have no problem accessing my company's VPN network (albeit slow).
You should contact Watchguard.
@yellicka
Just for clarity, these drives you're trying to access are not local, right?  You're having to access them through the internet to a remote server, correct?
