Required Speed Test
Required Speed Test
This is the required speed test, correct? If an Ethernet cable was required, wouldn't the installer have installed one? I see no Ethernet cable hooked up to  my 'wireless' installed  equipment.
This seems a bit much for  Hughesnet to require from a customer.
-perform the tests while signed into the testmy.net account
-do the tests while directly connected to the HughesNet modem with a LAN cable (NO ROUTER or Wireless devices)
-use the 12MB size download test file
3 REPLIES 3
Re: Required Speed Test
Would think it is supposed to come with a cable but can't say for sure since I still have the HT1100. Even though it can be used as a wireless router it is still a modem at its base and should come with a cable to plug directly into it. Plugging directly into it is the best way to set it up and troubleshoot it if having problems.
Distinguished Professor II
Redacted by maratsade.
What part of my post was modified?
