Router problem
ecoalex2
Tutor
Router problem
My wifi crashes, I have to restart the usb wifi card. , sometimes it has difficulty locating the router. The output in the lower panel shows 100% then varies, sometimes down to 35%, then climbs back up to 100%. it is constantly making swings, some subtle, some down to low, or no connection. This is on 2 of my computers. The problem started about 2 weeks ago, and continues.I tried reinstalling the wifi card driver, and any updates, for Linux, nothing seems to help. Any help appreciated
Tags (2)
13 REPLIES 13
Re: Router problem
When you say "router," do you mean the HughesNet wifi modem, or something else?
ecoalex2
Tutor
Re: Router problem
Hi, The Hughes modem wifi router. I also am seeing speeds under 8mps during the bonus time (now) 7 Am pdst. I still have mucho in the bonus allowance. Last nite I had speeds at .3-.4 mps . If you view my speed data you can see the speeds. Thanks
ecoalex2
Tutor
Re: Router problem
Hi, I just lost my connection to the router again. I had to restart the connection by clicking on the recognised router HUGg495758.
Re: Router problem
Is this still your Testmy.net results page? https://testmy.net/quickstats/ecoalex
The latest result there is from 2018.
ecoalex2
Tutor
Re: Router problem
Hi, I ran Hughes tests last nite, and this morning. If you can view the Hughes data , it is there. Thanks
Re: Router problem
As you may remember, to have speed issues addressed on this community, you have to follow a specific procedure, which includes running your tests on Testmy.net and providing the URL to your Testmy.net's My Results page.
ecoalex2
Tutor
Re: Router problem
Ok, I'll run some tests. My problem is connection, not speeds. No connection no speed Smiley Happy Thanks
Re: Router problem
Good morning ecoalex,
Thank you for posting! I ran diagnostics on your site and regarding connectivity, I'm seeing that two of your PCs (mac addresses ending in 6D and A9, both Dells) have a high delay. I'd like to make an adjustment to your modem to try to address this; it would temporarily disconnect you. Please let me know if it's ok for me to proceed.
Slow performance? Click me!
ecoalex2
Tutor
Re: Router problem
Ok, my latest tests https://testmy.net/quickstats/ecoalex Thanks
