I posted a couple weeks ago about issues we have had since we had HughsNet installed. Our connection is slow and inconsistent even on good weather days. It is likely that we will have to
drop the service as it has not lived up to promises.
To cancel, you will need to call 866-347-3292. You may have to pay an early termination fee if you're still under contract. See http://legal.hughesnet.com/ServiceTermsAndConditions-current.cfm
To avoid equipment charges, you will also need to return the equipment (modem, power pack, and the radio from the dish). You will get a kit to return the equipment when you cancel the account.
EDIT: the link to the instructions to remove the things that need to go back isn't working so I removed it. They send the instructions in the box you get when you cancel.
If you're having speed issues, the reps will need some speed tests to be performed in order to help. Keep in mind that your service is subject to the Fair Access Policy, which means that, when your data is exhausted, your service speed is throttled. If you're currently out of data, running the tests won't be of help, as they need to be run when you have data and your service is not subject to FAP and throttled. You can check your data levels with the HughesNet Mobile App, at the System Control Center, or under the Usage heading at the top of the page.
If you currently have data, please run some tests using the following protocol in order to get help...
-if testing upload instead of download, use the manual 4MB size upload test file
Additionally, Liz's reply to you from last week can be found here: https://community.hughesnet.com/t5/Tech-Support/Fairly-new-customer-haven-t-gotten-consistent-speed-...
