HughesNet Community
Slow speed
cladywood
Slow speed
I just got HughesNet this morning 25mbps. I had 10mbps with centurylink dsl. I am very disappointed as ever since the change my speed seems twice as slow instead of twice as fast. What gives?
2 REPLIES 2
@cladywood
To address speed issues, the first thing that needs to be done is to establish the speeds you are getting.  To do that, some tests will need to be run, but the results of such will also help to point in the direction of the possible cause of the issue.  The following is the protocol for the speed tests...
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform 3-5 tests during different parts of the day, then share the account results link with us here.
-If testing upload instead of download, please use the manual 4MB size upload test file
-post your testmy results URL here, it may look something like http://testmy.net/quickstats/yourusername
For a more in depth guide on running the tests, please visit: http://customer.kb.hughesnet.com/Pages/7001.aspx  (due to being an older page, the test sizes are incorrect for Gen5 (please use the test sizes listed above, in bold, for Gen5))
If you are unaware of how to disable the WiFi in the HT2000W, please see "How do I manage my built in WiFi modem?" in this PDF.  Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).
Brooke
Alum
Hi cladywood, welcome to the community and thanks for posting! Sometimes the modem may be fine tuning itself after activation that can cause the speeds to run a bit slowly; this should only last for a few hours typically. However there are some cases it can be up to 24 hours.
I pulled up your account and ran a speed test and on our end and the results came out pretty low. Because the modem is newly activated, some data is currently unavailable in my tools to pinpoint this issue. I would second Gabe's suggestion to run some speed tests also on your end to compare to my results. I would do some tonight and tomorrow, so we can see if the speeds improve overnight.
If you have any questions, don't hesitate to ask!
-Brooke
