The first thing to do would be to ensure that you're not out of plan data. You can do so on this modem page. If you still have plan data, the next step would be to run some speed tests, which the reps will need to both establish the speed issue and help point them in a direction of the cause. The instructions for the speed tests are as follows. Please be sure to read the instructions thoroughly before running the tests to ensure that they are run properly, then post the testmy.net "My Results" page URL (the address in the address bar) into a reply so that the test results can be viewed.
Edit:
Because there is the possibility of an equipment or aiming issue, for now I would just run a few tests, as in maybe three, just to establish the issue. I wouldn't bother running a whole bunch of them at this point, as the reps will likely want to run remote diagnostics on your HughesNet equipment, and if it turns out that there is something wrong, a whole bunch of tests while the problem exists would be a waste of your time. So again, just maybe run three tests to show the issue for now. The reps also may need some personal information from you to locate your account in order to run the remote diagnostics on your HughesNet equipment, but they will ask for that information to be sent via Private Message, for which they normally provide a link.
-if testing upload instead of download, use the manual 4MB size upload test file
