Speed drop
pbparker
Speed drop
Speed drop in the last month.  1100 modem, beam 34.  Speeds have dropped from 5 digits download to as low a 1 meg.  Haven't seen decent download or upload speeds in over a month.  It used to be great.  All diagnostics on the modem check OK.  Signal strength is always the same.
130 REPLIES 130
Ricky
Tutor
Re: Speed drop
I am with you on this one. My speed have jumped off a cliff as well.
Ricky
Tutor
Re: Speed drop
http://testmy.net/quickstats/RickyYak1
Result show good speeds previously. Not so good now with no computer or router changes.
BirdDog
Re: Speed drop
Ricky, yours appears to just be today and may be transient, pbparker is saying his has been bad for over a month. Not sure his and yours are related.
Ricky
Tutor
Re: Speed drop
Mine have been bad for a while now. My stats just show today. However they have been bad for a while.
BirdDog, you know I am not into fly by night results.
BirdDog
Re: Speed drop
The stats show back to June 03, the ones in your stats don't look bad that far back. Maybe do some at different times of day.
June 29th shows a 30.35 Mbps.
Upload tests need to be either 1.5 or 2 MB in size.
Gwalk900
Re: Speed drop
If it's across the board it may be general oversell/overload.
I have the Ultra plan but I see it's no longer offered at my nearby address location.
Still, once documented, the Engineers may be able to sprinkle some Magic Dust or swap/add servers. Whatever the root cause is ... and that takes troubleshooting as well as persistence.
Chris11
Alum
Re: Speed drop
Hello pbparker,
Thanks for posting and welcome to the community! I'm sorry to hear of your experience. First off can you tell me what website you are using to run tests? I see a few ran on our website with these results:
Just not sure if you your using others as well. These are certainly low for your plan, however if you don't mind heading over to www.testmy.net and also running some that would be great. Run a batch of tests throughout the day. Some morning, afternoon, and night. Use 12 MB manual test size for download and 2 MB manual test size for upload tests. I'll be adding token bandwidth to your account to make up for the data that will be used. Also one computer connected via Ethernet is key as well.
I do not see anything reported recently about your Beam or Gateway. However I am noticing other defining factors in the diagnostics I have run today. In conjunction with your speed test results(if they continue to be low) we can definitely make a case for our engineers to take a look. Hope to hear from you soon.
Thanks.
Chris
pbparker
Re: Speed drop
Here's my stats from consumer tests.
Date/TimeDown(kbps)Up(kbps)07/13/2016 17:14:34
1529
649
07/13/2016 17:13:11     1759   215
07/12/2016 13:05:19      6233  1302
07/06/2016 14:43:22     1185    872
07/06/2016 14:41:58     1686    1264
07/02/2016 10:52:37      3135    352
07/02/2016 10:51:23      1774    55
06/28/2016 16:49:33       3940   336
06/28/2016 16:48:25       4201    531
06/24/2016 22:49:19       1546   519
06/24/2016 22:47:52      2139    841
06/24/2016 22:46:37      2477    558
06/05/2016 14:29:42      2145    1458
06/05/2016 14:27:54      1568    614
05/29/2016 11:43:49      18756   552
05/13/2016 14:42:08      12890   997
05/10/2016 15:08:20      19811   1455
05/06/2016 13:24:09       3392    1389
05/06/2016 13:23:18       13196   889
04/24/2016 18:28:35        918      931
BirdDog
Re: Speed drop
Again, what Ricky's stats show aren't that bad except for a few today. Only saying he needs to run some at different times of the day.
Some results are significantly higher than "up to" speed.
