HughesNet Community
Why was my speed pushing 30mbps when installed now it's less than 5
Bretboarder
The first few days it worked fine. Now we are in the kbps a lot of the time. And we are still in the unlimited first 20 days period. VERY FRUSTRATED
1 REPLY 1
@Bretboarder
Has the speed dropped round the clock?  Are you connected via WiFi, and, if so, if you connect a device via LAN cable does that device experience the slower speeds, as well?
