gen 5 system
Re: gen 5 system
@shadow357 wrote:
I know that the current speeds I am getting will start dropping as new customers come to Gen 5 but as long as I can get better than anything available out here I am happy.
Although this is technically true, and will most likely drop somewhat as the beams fill up, as well, it will probably be quite some time before this happens.  The ES19 has more than double the capacity of the ES17, and it will take a long time before the ES19 reaches anywhere near capacity.
