signal unstable, internet keeps cutting out
Re: signal unstable, internet keeps cutting out
Good morning bumsdw,
Thank you for letting me know. The modem order was for the 96055 zip code. I do apologize for the delay, it seems there was a system issue last week that affected HT2000w RMAs. It has supposedly been fixed by now so I'm reattempting to get that modem out to you.
Hi bumsdw,
Thank you for your patience, I have your UPS tracking number for your replacement modem. Please check your private messages in the top right corner of the community page as I've sent the tracking number to you via PM.
bumsdw
I like the new modem with built-in wireless. However, it did not correct the problem. The signal is still unstable and I am unable to do anything that requires a solid network connection. I am beginning to think that this is not a hardware problem but rather a service deficiency.
Hi bumsdw,
Thank you for the update on the new modem. I'll have to double-check to see if a radio replacement would be appropriate in your case. I'll post back once I have any updates.
How has the service been so far since the modem swap? I ran diagnostics on your site and see a significant decrease in modem errors.
Looking forward to hearing back.
bumsdw
Hi Liz,
Sorry for the delay getting back to you. The service was was actually much better for a short period of time. After about two weeks the stability started worsening, although not as bad as it originally was. Now it occasionally cuts in and out. Now I can`t even check my usage, it says ref FAP-1 whatever that means. So I`m just living with it until I can try something different. Thanks for your help, David (bumsdw).
Hi David,
Thank you for getting back to me. Let me escalate your concern about that FAP-1 error message up. I'll post back once I have any news for you.
