speed
speed
Hi. I am new to HughesNet and satellite internet. My dsl I had was 10mbps. Yesterday they installed HughesNet. I noticed tonite it has seemed kinda slow loading pages. I tried you tube but vids would load real slow and then stop every few seconds. I did a speed test yeaterday and it was 30mbps. I just did a couple tonite and the download speed was 1-2mbps. Is this normal?
5 REPLIES 5
Re: speed
An evening slowdown is normal due to that being when the highest number of people are on, but 1-2 Mbps is VERY low.
What beam are you on?  You can see which beam you are on at the following page...  http://192.168.0.1/#!/home/information
Look in the "Satellite" box.  It's listed as Beam ID.
Re: speed
Beam 12
Re: speed
Before performing the speedtest troubleshooting, if you have the Video Data Saver feature enabled (enabled by default) then you should set your streaming resolution to Auto, or 480p and lower.  Otherwise you will experience frequent buffering.  To stream 720p and higher, you must disable Video Data Saver.
That aside, if you have taken that into account then please create a testmy.net account and perform 3-5 tests during different parts of the day. Then share the account results link with us here.
Please keep in mind that Hughesnet will only accept testmy.net and the official Hughesnet speed test results. Tests from other sites like speedtest.net are not accepted due to the compression technologies and latency that satellite deploys.
-If testing upload instead of download, you must use a 4MB size upload test file
Re: speed
Where do i find the video data saver feature?
