ConnieD
4 years agoNew Poster
Daily data increased after upgraded to higher data plan
I have been on the 25MB plan for over a year, my daily average has been around 2.5MB. However, I always ran out of data about 7 days prior to the end of the month. So I decided to bump up to the ne...
4 years agoDistinguished Professor IV
Changing plans doesn't increase usage. Usage increases usage, so something must've changed on your end and you're not aware of it. Finding out what the culprit is may be tricky, and will require some detective work on your part. Did you buy a new smart device? Did you connect a TV to the internet? It could be so many things.
