James11
11 years agoNot applicable
How to ...
How do I remove the satellite thing. I call it a turtle with its head stuck out. But I know there is a technical name. Sorry I need to have someone else remove this for me. I cannot reach it and I am ...
11 years agoModerator
Hello James,
When you receive the box to return the equipment, it will have instructions and should have a removal tool (to my knowledge) but I am not sure if that tool was only needed with the older radios. Are you saying that someone else will be removing this for you or you need someone to come out and remove it?
Regards
Regards
