Setting up Raspbian on my Raspberry Pi?
For any of you that might be able to help, I'm a little lost with what I should to do set up Raspbian to use like I would Windows. What I mean is, to feel comfortable using it on sites where I have ...
I think I may have found the answers to at least some of the questions I had regarding having a secure setup...
https://www.raspberrypi.org/documentation/configuration/security.md
From this, I gather that I need to....
- Change the default password
- Create a new user with a new password
- Make Sudo require a password
- Install a firewall (I'm sure configuring it is going to be REALLY fun :( )
Anything else?
If I need to do more than what's listed, please feel free to tell me.
Thanks, folks.
Edit: Found this, too, though it says some of the same things as the other site... https://makezine.com/2017/09/07/secure-your-raspberry-pi-against-attackers/
