DavidSTX
9 years agoFreshman
Gen5 HT2000W Power Usage
In another thread, CORROSIVE (Thanks!) posted a link to HT2000W installer's guide, and it mentions the modem's power usage is rated at 75 watts. Does anyone happen to know what effect, if any, turnin...
DavidSTX,
According to my APC Back-UPS Pro 1500va unit, the modem (HT2000w) is drawing about 40w at idle with clouds and a signal of ~110. Granted this is using the information the UPS provides and isn't very accurate, it should be a better estimate than initially stated. Probably wouldn't go up but 5-10w at most in stormy weather.
C0RR0SIVE
C0RR0SIVE
9 years agoAssociate Professor
Router =/= wifi radios... They are two seperate beasts with in the same unit. There is no way to eliminate the router circuitry and disable the CPU with in the unit.
timothysouthwar
9 years agoNew Poster
Thanks, Corrosive. I understand now.
