Legacy plan are we stuck forever? ??
Yes the dish appears to be at 37 where the line is on the number.....
But, I have a Directv dish that I no longer have in service which points actually further east and is set at about 30. Actually the directv guy was much friendlier and spent more time trying to figure it out.... the original install of Hughes was a joke cause even though I told everyone it had to go on a pole, he said he didn't have 1 and was not pleased and put it on that metal roof platform lying in the driveway free standing....dog chased a racoon and caught it at the sat and their short but intense fight bumped and moved the dish, Hughes exec customers service had me take a photo and paid for him to return and do it correctly.
From what that installer said years ago the sat was behind the bigger trees but the directv one does not point at those trees and from the angle that page gave me you posted I am just guessing but It seems that echos star may be between the two of them
Do you know if any of those sat finder apps actually work... I am going to try and download 1 and see what I can come up with, it says they help you point your dish, but so many worthless apps who knows.
There may be some hope yet :)
I had forgotten about DishPointer, which is similar to a site already mentioned, but it's pretty easy to use. I entered my address and hit search, which it then found, and then I selected the Echostar 19 satellite in the list, but the list has both the ES19 and ES17 satellites. Below is what it shows for my house with the ES19. And if you tick the options box on the upper right of the picture it will add that little red pointer, which you can move and will show you how tall an object can be before it will be in the way. I would probably subtract a few feet of height from that part, as I don't know if I trust what it says completely, but the pointing (the green line) is dead on. I have the green pointer sitting pretty much right where my dish is (you can move that thing to where your dish would be, or is already) and it points directly at the satellite, and the pointing I trust completely. It's just the height at the red thing that I subtract a little from, as it says 49 feet right there, but I think a 48 foot tree would still be a little too tall, so I take a few feet off of what it says for height. The tree that is showing there, and which I cut down last March, just before my Gen5 install, was actually about forty feet, and that would have been pushing it as in the top being in the way. It's a pretty handy website.
So, go to that site, enter your address and click search, then, when it shows your home, move the green pointer to where the dish already is, or where you think it might go with a new installation. Then select the Echostar 19 from the drop down list on the upper right and see where it points to in order to see if it's viable. Then change to the Echostar 17 to check it, as well, though I can't say that the Echostar 17 would be an option offered for sure. I only mention it due to them having put some Gen5 people on the ES17 for various reasons.
What the picture below is saying is that where I put the red mark is 63.4 feet away from the point of the green mark, which is exactly where my dish is, and at that 63.4 foot distance it's saying that anything under that height (49 feet) will not be in the way, though again, I would shave a few feet off of that height, not only because I think it's a bit off, but also to give room for tree growth. Again, though, I cut that tree down, but now the one a little closer to the house and just under the line is growing too fast and will need to be cut down this spring. It's a very fast growing locust tree, and I hate those long thorns on those things, anyway. :p
Also, what gokartergo24 suggesting might be a good idea, too. He's an installer, so he would know. Also, and I can't speak for them, but it's possible that one of the reps might have some suggestions, too. I'll tag them so they see this thread.
I really hope that there's something that would work. But, of course, in the end you always have the Verizon Wireless option, so at least there's some type of light at the end of the tunnel, either way. :)
Liz Amanda Is there an option that might work for tpp or some way to see if upgrading is feasible?
Edit: I can't really say much about the various satellite apps for Android smart phones. I tried a couple one day with my phone, and while one locked me out of being able to enter any info manually (the presets didn't include the ES19) without paying for it, which I wasn't about to do, the other one was completely free, but I couldn't figure it out. :p
