BirdDog
10 years agoAssistant Professor
Netgear releases patched firmware to fix vulnerability.........
Read about it here: https://threatpost.com/netgear-publishes-patched-firmware-for-routers-under-attack/115006/
BirdDog
Cuddlebug, it is available here and affects the eight router models listed: http://kb.netgear.com/app/answers/detail/a_id/29959
You can go into your router web management interface by typing its IP address into your browser search bar and hitting enter. There will be able to see what version of firmware you have.
If you don't have remote access enabled on your router then the only way someone could hack into it is if they had access to it on your internal network. Many people enable remote access for various reasons and they are the ones who are really vulnerable.
- 10 years ago
- 11 years ago
