25mps speed but Safari and Firefox load very slow
Good morning RJMFHWA,
Hi RJMFHWA,
Thanks for posting and welcome to the community! Your SAN ends in 37, correct? If so, the diagnostics I've run on your site shows that the HughesNet equipment is working normally, with the modem receiving 40+ Mbps in download speeds. Currently I only see one connected device on the network, an iPhone on the 5Ghz network which only has a fair signal. You can try moving closer to the modem to see if things improve, or switch to the 2.4GHz network which has a bigger range than the 5Ghz network.
