tvignoe
10 years agoNot applicable
- 10 years ago
BirdDog
10 years agoAssistant Professor
Connecting the DirecTV box to your HughesNet is not advisable, it will eat lots of data in the background and pausing/time shifting will also use more data.
The best way to do Netflix from my experience is using the browser on a computer connected to the TV using HDMI.
- 11 years ago
