tvignoe
10 years agoNot applicable
- 10 years ago
10 years agoDistinguished Professor IV
-rs,
I don't have any experience with the product, but from what it says on the link you gave, I wouldn't count on it working. It mentions the incompatibility with satellite service.
- 11 years ago
