tvignoe
10 years agoNot applicable
- 10 years ago
maryjuelke
Was told by Verizon that Hughs net would need to unlock the ports on their modem in order for it to work. Tried talking to Hughes net and they refused and said I would need to get one of their phones. Its not that its not compatible, it that Hughes net refuses to unlock their modem in order for us to use the verizon booster.
- 11 years ago
