- 10 years ago
- FMVR8 years agoNew Poster
I have been on the phone all day with Hughsnet's Home Tech Support. Hughsnet does not support VPN. Therefore cellphone network extenders do not work with their system. So either I carry two internet providers so I have the capability to connect our network extender or I find a different way to make phone calls. Not sure how we are going to go right now. But I spent a lot of money to get a service that doesn't cover our needs.
- 11 years ago
