tvignoe
10 years agoNot applicable
- 10 years ago
mmhtw1974
I called Verizon and was assured that the new Network Extender 4G would work. $279.00 later, it would not work and tech support said that it will never work. I have the home phone from Hughes and it is just fine. I can survive without my cell!
- 11 years ago
