Are those turkeys? I can't really tell what they are. Are the ones in the background the same as the ones on the road?
Yep. They're all turkeys. A few little ones in there too.
If you click on the pic it should expand.
@GabeU wrote:If you click on the pic it should expand.
I did. Still couldn't tell. 🤣🤷
It's not very good quality when zoomed in, but you can see them a little easier here...
Now I see it! 👍👍
