Hughesnet Community
Roof is being repaired/replaced
jehovah1
What do I do with the equipment?  Do you have to come back to reset the equipment?  Can I have the service on a pole rather back on the roof?
1 ACCEPTED SOLUTION
This section isn't for HughesNet support.
You should repost this in the Tech Support section to get the particulars and what it would entail.
And yes, the dish can be mounted on a pole as long as there is no obstruction, but the installation must be performed by a Hughes tech.
3 REPLIES 3
Thank You Gabe
You're very welcome.  🙂
