Gen5 Upgrade with no change to dish?
I just upgraded from Gen4 to Gen5. I was told I will receive my new Modem/Router in 7 to 10 days. I asked if there was a local service call required to "point" the dish to the new Gen5 satellite. I was told that this was not necessary. "Just install the new modem/router and in less than an hour all will up fine."
Does this make sense? I remember reading that the dish had to be repointed to move to the "Gen5 satellite". Thanks for any clarifications on the upgrade steps.
Echostar 17 is now considered a Gen 5 satellite just like Echostar 19. To be honest with the recent problems with some beams on E19, you may bebetter off staying on E17, at least for the near term.
Also, some places are served by both satellites, hopefully they are trying to balance the load between the two. So maybe they determined it was best to keep you on the older satellite.
All that is required for Gen 5 service is the new modem/router combo (HT2000W).
OK. This makes sense. Thank you for the quick reply.
- MarkJFineProfessor
Some regions are still served by Jupiter 1 and require no dish adjustments.
- BirdDogAssistant Professor
- jacobsenlcNew Poster
OK. Thanks for the quick reply.
- dacarriganSpectator
What was the cost of the upgrade to GEN5
dacarrigan wrote:What was the cost of the upgrade to GEN5
No matter the OP's cost, you can find out what your cost would be by visiting https://www.hughesnet.com/ and inputting your address, or by calling the number on the site.
